Question:
How can I set up a driver and its tags inside an XObject? How to make each tag to be configurable when inserted in XObject instances?
Solution:
- The driver must be set up and its tags must be created normally, as it would be done outside a library.
Create properties in the XObject, named PropN1, PropN2, PropN3, and PropN4, for example.
Link bidirectionally the tag’s N1, N2, N3, and N4 properties to the previously created ones.
Save and register the library.
Now each tag can be configured in its corresponding instance, as long as there is one tag for each XObject.
