Question:
When I run the Symbol Library application, the following message is displayed: “Hasp not found (15)”. What does it mean?
Solution:
To run the Symbol Library application, you will need a SCADA Configurator
license (version View, MMI or PRO). Additionally, you should also install the Symbol Library‘s latest version, which can be downloaded directly from Elipse’s website.
