KB-38948: Local SQL Server database.
Question:
Even when configuring a SQL Server database as ComputerName\SQLEXPRESS, there is a need to repeat this configuration every time the machine changes. Is it possible to set up the database as local?
Solution:
Yes, you will need to repeat these settings whenever you change machines. To prevent this from happening, set it up as .\SQLEXPRESS.
Print Friendly, PDF & Email
Leave a Reply
