Question:
How can I create an animation with several figures?
Solution:
To do so, go to E3Studio and follow these procedures:
- Insert the figures into Resources.
- Rename those figures, removing extensions, accents and spaces.
- Insert a Demo Tag in the Viewer and set up Maximum (number of figures) and Type = 4 (ramp up) properties.
- Insert a Figure object on screen, and then close the screen that will open.
- Create table link between the Figure’s FileName property and the Demo Tag’s Value property.
- In the Figure’s Min and Max fields, write 0 – 1, 1 – 2, 2 – 3, and so on, up until the total number of figures.
- In the Figure’s Value field, write the name of the figures inserted into Resources.
Man, i don’t get it. Can you please do a video? If you could, of course.
Hello Yamimura. Can you please post your doubt in this article? I passed your video suggestion for the responsible department, but I can help until it’s ready.
Hello, Yamimura.
The Post of the forum shows, visually, the step-by-step of this KB article: https://forum.elipse.com.br/t/answer-the-question-in-kb-38450-creating-an-animation-with-several-figures/3230
