Question:
How can I enable the Driver DNP 3.0 Master to send unsolicited messages?
Solution:
To do so, you must enable the Enable Unsolicited on Startup option in the Driver’s settings window. In addition, the I/O Tags’ type must be set as Event (for further information, check the table 3 in the Driver DNP 3.0 Master’s Manual).
