KB-37949: Changing E3 Viewer’s resolution.
Question:
How can I change E3 Viewer’s resolution?
Solution:
To do so, follow these steps:
  1. Open E3Studio.
  2. In the Organizer, right-click the Viewer and open its properties.
  3. On the Viewer’s properties window, access the Settings tab.
  4. In the Viewer Resolution item, change the resolution to better suit your needs.
Print Friendly, PDF & Email
Leave a Reply
