KB-37912: Inverting a figure in E3.
Question:
How can I invert figures in E3?
Solution:
To do so, follow these procedures:
  1. Right-click the figure and select the Convert to Symbol option.
  2. Right-click again the figure and select the Explode Symbol option.
  3. Click on one of the figure’s corner and drag the mouse to the reverse side.
Note: when using non-vector images, you must convert them on an external program and add them to E3 as a resource.
Print Friendly, PDF & Email
Leave a Reply
