Question:
How are tags counted in Elipse SCADA for licensing purposes?
Solution:
The following tags are counted for licensing purposes in Elipse SCADA: RAM, DDE, Demo, Expression, PLC, and PLC Block. Each block element and mapped bits arecounted as one tag in this case. Chrono and Matrix tags are not counted for these purposes.
To view the overall tag count, access the Organizer, select Application, and click Statistics.
