KB-37409: S7Functions Driver not enabling Extras option
Question:
Why is the Extras option not enabled for configuration even after DriverLocation property has been set with the S7Functions Driver’s DLL?
Solution:
According to the driver’s manual, to fix this problem, you should install Siemens’ S7Functions in the same machine where Elipse’s driver/application is.
Print Friendly, PDF & Email
Leave a Reply
