Question:
How can I export alarms to be configured in Excel, and then import them back to E3 after that?
Solution:
To do so, you must insert an area and an alarm in E3, right-click the AlarmConfig, and select the Export option. With this, a .CSV file is created to be configured in Excel.
After the Excel is set up, just import the .CSV file back to E3. To do so, you can use the Area.ini file, which is in the E3 installation directory’s Templates folder, as a template.
