Question:
Can I establish communication with Siemens’ S7-1200 PLC via M-Prot driver?
Solution:
Yes. To do so, you must select the protocol ISOTCP (Ethernet) and set the following items:
- Uncheck the option Use default TSAPs
- Set property Source TSAP (hex) = 0100
- Main Rack = 0 and Slot = 1
- Set N1 = 0 in all I/O tags*
*Check driver´s manual.
Note: This article also applies to S7-1200 models with new firmware version.
HAVE ELIPSE/E3 DEMO APPLICATION OR WHICH DRIVER USED FOR COMMUNICATION WITH Siemens’ S7-1200 PLC
