Question:
Can I use a USB/parallel converter to connect the hardkey to the computer?
Solution:
We don’t recommend that you use a converter, nor do we assure that the hardkey will work properly. Therefore, we recommend that you upgrade the parallel hardkey to a USB hardkey.
