KB-36695: Script at a tag’s OnRead() event not being executed.
Question:
Why is the script written in a tag’s OnRead() event not being executed?
Solution:
To execute it, you must set EnableDeadband property as TRUE. If the tag is not used in application, set AdviseType property to AlwaysInAdvise.
Print Friendly, PDF & Email
Leave a Reply
