Question:
How can I configure the CSV file to import tags via ABCIP driver?
Solution:
To do so, follow these procedures:
- Export the CSV file via Allen-Bradley’s software;
- Open the CSV file and change Name‘s column name to IOI;
- Delete all the other columns;
- Create a column named N2 and insert the values that correspond to the indexes in each tag;
- Save and close the file; Salve e feche o arquivo;
- On driver’s CipAddressess tab, click Import From CSV button and import the corresponding file.
I have to communicate with Allen Bradley Guardlogix PLC. Please reply which driver to be use.
