Question:
How can I copy a screen inside a Project?
Solution:
This can be done by exporting the original screen, and then importing it later. To do so, follow these procedures:
- Select the screen to be copied, right-click it, and select the Export as CSV file option.
- Insert a new screen in the Project.
- Import the CSV file previously created to the new screen.
NOTE: Using Elipse E3 version 3.1 or higher.
