Question:
Which type of file can be inserted as a resource in an E3 application? Can an I/O driver be inserted as a resource?
Solution:
You can use the Insert Resource In option to insert images (JPG, GIF, BMP, PNG, ICO, WMF, EMF, TIF) and sounds (WAV). I/O drivers do not work when inserted as a resource.
For more details, check the attached example application developed in Elipse E3 version 3.2 build 260.
