KB-36059: Executing a double-point command via DNP driver. 25 de March de 2019Elipse SoftwareLeave a Comment on KB-36059: Executing a double-point command via DNP driver. Question: Which object and variation must be used for a double-point command via DNP driver? Solution: In a DNP driver, you must use an Object 12, and Variation 1 – Control Relay Output Block. Este artigo foi útil? Was this helpful? Submit Rating Classificação média - Average rating 0 / 5. Count: 0
