Question:
How can E3 logs be generated?
Solution:
- For Elipse E3 versions prior to 3.0, you must create the folder “C:\E3Logs”.
- For versions after 3.0, Elipse E3 will create the folder “C:\eeLogs\E3” automatically.
In either situation, these logs will be generated inside this folder as soon as it has been created.
From version 3.0 on, use the following programs:
- Elipse Event Log Viewer (to view logs).
- Elipse Event Log Collector (to collect logs).
- Elipse Event Log Export (to export logs to another format).
