Question:
Can E3Viewer‘s and E3Server‘s versions be displayed on a screen in the application?
Solution:
Yes. To do so, just use VBScript’s GetFileVersion() method to read the versions of E3Server.exe and E3Viewer.exe files, which can be found at \Bin folder where E3 is installed.
NOTE: Attached to this article is a sample application developed with Elipse E3 version 3.2 build 260.
