Question:
How can I create a list of devices based on the ICD file?
Solution:
To do so, create a Driver object and point it to the .DLL file corresponding to IEC-61850 driver. Then, on Settings tab, select the option Browse SCL Files and choose the file with .ICD extension.
After the file has been imported, the driver will create a list of relays according to the ICD file, each one with an individual IP and respective tags.
