KB-35634: Exchanging memory contents between hardkeys.
Question:
Can I exchange memory contents between hardkeys?
Solution:
No, you can’t, because each hardkey has a uniquely generated code. What you could do is contact the Elipse Software‘s sales department and require a hardkey reprogramming, which will make one hardkey’s contents similar to another.
Print Friendly, PDF & Email
Leave a Reply
