Question:
Why does the following error occur when exporting a report to Excel?
ActiveReports Excel Export error: pages collection or RDF file may be corrupt
Solution:
This error occurs because the report’s lines number is higher than the maximum number of lines allowed by an Excel’s spreadsheet. The lines limit in a spreadsheet of Excel’s 2000 and 2003 version is 65.539, as you can see by clicking here.
To solve this problem, export less registers by using a filter by date with a lower period range.
