Question:
When I run the application or the Domain Check, the following message is displayed:
“The ‘C:\MyProjects\Prj\project1.prj’ path is not in the Domain folder. This may cause problems if the Domain is removed to another folder or if access to the Remote Domain is required. Remove this file from the Domain, copy it to the Domain file, and re-insert it in the Domain, making sure the path is relative.”
What does it mean? How can I fix this?
Solution:
This is just a warning message to inform the user that the ideal settings in this case would be placing the PRJ and LIB files in the same .dom folder, or then in subfolders in this directory.
