Question:
How can I open a modal screen by using a button?
Solution:
To do so, follow these procedures:
- Insert a button onto screen and access its Scripts tab.
- On the toolbar, select the button’s Click event and the Open modal screen pick.
- Then, set up the name of the screen to be opened at Open Screen field. All other parameters, regarding position and window style, are optional.
