Question:
Why is error code 80070057 being displayed when I to save a few changes made in a project at E3Studio?
Solution:
This error is generated whenever you try to save any changes in the object after it has been saved at run time (via Save() method).
To avoid this behavior, if the application uses Save() method, the project file must be updated in the Studio before any changes take place on it. Otherwise, the changes made in the Studio (in the object that was saved at run time) will be lost as soon as the project is updated.
