Question:
If I try to generate the Historic’s structure in an Access Database, the following error occurs:
Why does this happen?
Solution:
This happens because there is a limit of 128 fields per Historic, including the E3TimeStamp, which was exceeded by your application. To work around this, we suggest creating more than one Historic, or migrating to SQL Server, where the limit is 512 fields per Historic.
