KB-34421: Differences between NBR14522 and NBR14522_SU drivers.
Question:
What is the difference between NBR14522 and NBR14522_SU drivers?
Solution:
  • NBR14522 – Reads mass memory, and is read by the optical port;
  • NBR14522_SU – Reads the user’s output, and supplies data in real time, every full second.
Print Friendly, PDF & Email
Leave a Reply
