KB-34374: Editing applications in HotStandBy.
Description:
Is it possible to change applications running in Hot-Standby mode? What is the best way to perform this?
Solution:
Yes, it is possible to perform any change. To do so, it is recommended to follow these procedures:
  1. Copy all files (*.dom, *.prj, *.lib, etc.) from the application running in Hot-Standby mode to a third computer, with E3 Studio installed.
  2. Perform all changes needed, and then save the application.
  3. Close E3 Studio and copy all application files to both computers running in Hot-Standby mode (overwriting the existing files).
  4. In any computer running in Hot-Standby mode, right-click the E3 Admin icon, in Windows Notification Area, and then select the option Domain – Refresh). Thus, application files on both computers are updated!
By performing the previous steps, the system keeps running and the application update is performed, without loosing Hot-Standby functionalities and system operation.
Print Friendly, PDF & Email
Leave a Reply
