Question:
Why can the screen open in Elipse SCADA be only monitored via web?
Solution:
Whenever a screen is opened in Elipse SCADA, an HTM file corresponding to this screen is created, which makes it possible to visualize it via web. If it is closed, the HTM file is deleted, and the screen is no longer visualized. To avoid deleting the file, we recommend “hiding” the screens that are not being visualized, and not closing them. You can, for example, leave the window open at an X Y point outside the monitor’s resolution.
