Question:
Which port is used by the Viewer to connect to the E3Server?
Solution:
The default Windows port used by Elipse E3 is 6515. This can be seen via E3Tweak on the section about the E3Server, or directly via Windows register: HKEY_LOCAL_MACHINE\SOFTWARE\Elipse Software\E3\E3Server\REC\IPPort
