Question:
How can I display different messages from those defined as default on the E3Alarm‘s Severity field?
Solution:
To do so, select the Severity field in the E3Alarm‘s properties on Columns tab. Then, click the Properties button, and write the desired messages on the Formatting field, separated by a semicolon. These messages must be written in priority order: high; medium; low.
How to show same messages in report?
