Question:
How can I check whether an XObject’s IOTag property is empty?
Solution:
To do so, you can use VBScript‘s IsNull method. This method returns TRUE if the variable has any type of value in it, and FALSE if it is empty.
Example of script:
If IsNull (property) Then
MsgBox "there are tags"
Else
MsgBox "empty"
End If
