Question:
How can I add values to a ComboBox?
Solution:
To add values to a ComboBox, you must create a script using this object’s AddItem method. This method should preferably be used in a ComboBox’s OnStartRunning event.
Example of script:
Sub ComboBox1_OnStartRunning()
Clear()
AddItem "Item1"
AddItem "Item2"
NOTE: Item1 and Item2 are the values to be added to the ComboBox.
