KB-33612: Communicating with several PLCs via RS485 network.
Question:
Can I use a Modbus driver with several PLCs on a RS485 network?
Solution:
Yes, you can. Each device must have a Modbus address on this network. At each tag’s or block’s N1 parameter, you must inform the Modbus address to be connected. This will only work with serial communication.
Print Friendly, PDF & Email
Leave a Reply
