Question:
Why is Run/Stop Domain button disabled in Demo mode, and therefore the Domain cannot be executed?
Solution:
This probably happens because Hot-Standby is enabled, and the Domain was opened in a server that does not belong to the architecture configured in the Domain options. To enable Domain execution, you must access its options and disable Hot-Standby. To do so, right-click E3Admin–Domain–Options–Options tab.
OBS: you will need a hardkey to perform this procedure.
