KB-33436: Driver licenses for Ethernet communication.
Question:
How many licenses are needed to communicate with a network with five PLCs via Ethernet?
Solution:
To do so, you will need one license per driver object in the application, i.e., um license per IP address, which means you will need five driver licenses altogether.
Print Friendly, PDF & Email
Leave a Reply
