KB-33266: Increasing a Text’s font at runtime.
Question:
How can I increase the font on a Text object at runtime?
Solution:
You cannot edit the font of a Text object at run time. However, you can use the Label object (MSForms) and change the Font.Size property via scripts.
For example: Label1.Font.Size = 14
Print Friendly, PDF & Email
Thoughts on “KB-33266: Increasing a Text’s font at runtime.
    1. Bom dia Guilherme!
      Obrigado pelo comentário!
      Para o objeto “Label”, o correto é conforme descrito no artigo:
      ‘NomeObjLabel.Font.Size = Tamanho
      Label01.Font.Size = 20
      Para o objeto “DrawString”, que acredito ser o comentado por ti, é conforme disse:
      ‘NomeObjDrawString.TextFont.Size = Tamanho
      Text01.TextFont.Size = 20
      Atenciosamente,
      Marco Antonio
Leave a Reply
