KB-33170: Elipse E3’s compatibility with Windows Vista.
Question:
Is Elipse E3 v. 2.5 compatible with Windows Vista?
Solution:
No, E3 version 2.5 is not compatible with Windows Vista. You must update E3 to version 3.0 or higher; these versions are fully compatible with Vista.
Print Friendly, PDF & Email
Leave a Reply
