Question:
With the application open in E3Studio, the 80070020 error occurs when I try to select a project with Tools–Defragment menu. How can I work around this?
Solution:
The 80070020 error means “The file is already being used by another process.” In this case, right-click each project via Organizer, and then select the Defragment option.
