Question:
How can I zoom in or zoom out on screen?
Solution:
SCADA does not have a zoom tool like E3.
However, you can change Width and Height properties of the objects at runtime via scripts, which will cause a zoom-like effect on screen.
For zoom in x2, for example, you should have something like this:
Bitmap1.width = Bitmap1.width * 2
Bitmap1.height = Bitmap1.height * 2
For zoom out x2, you should have something like this:
Bitmap1.width = Bitmap1.width / 2
Bitmap1.height = Bitmap1.height / 2
NOTE: The sample application was developed in Elipse SCADA v2.29 b092.
