KB-33048: Screen objects’ dimensions when increasing the application’s resolution. 25 de March de 2019Elipse SoftwareLeave a Comment on KB-33048: Screen objects’ dimensions when increasing the application’s resolution. Question: If I increase an application’s resolution, will the screen objects’ dimensions automatically increase too? Solution: No, they will not. So, you must manually increase the screen objects’ size too if necessary. Este artigo foi útil? Was this helpful? Submit Rating Classificação média - Average rating 0 / 5. Count: 0
