KB-33046: Elipse E3 and Elipse SCADA running in 64-bit systems.
Question:
Are Elipse E3 and Elipse SCADA compatible with Windows 64 bits?
Solution:
Yes, both systems have been compatible with 64-bit processors and operating systems since their following versions:
  • Elipse E3: Compatible since version 3.0.
  • Elipse SCADA: Compatible since version 2.29 build 30.
Print Friendly, PDF & Email
Leave a Reply
