KB-32994: Video and audio files.
Question:
How can I insert video and audio files into an application?
Solution:
To run a video file, use AVI screen object, according to the example below. To run audio files, use the Global Manager’s PlayWave function.
NOTE: Attached to this article is a sample application illustrating the points discussed in this article.
Exemplo Video
Print Friendly, PDF & Email
Leave a Reply
