KB-32539: Importing tags and subfolders.
Question:
When importing a tags’ folder at a IEC 61850 driver, why are its subfolders not loaded?
Solution:
This is how the driver usually works. To import all tags correctly in this case, you must open the folders (Logical Devices) before import.
Print Friendly, PDF & Email
Leave a Reply
