KB-32430: Changing time interval on the horizontal axis.
Question:
The horizontal axis is set with a 1-hour interval. When the application runs, the times are displayed with no minutes (9:00, 11:00, 13:00).  Is it possible to change this value so that it can display times such as 9:30, 11:30, 13:30, for example?
Solution:
No. The value displayed in this axis does not support minutes.
Print Friendly, PDF & Email
Leave a Reply
