KB-32426: Importing screens from Elipse SCADA to Elipse E3.
Question:
How can I import a screen from Elipse SCADA to Elipse E3?
Solution:
To do so, first you must export the screen from Elipse SCADA. Via Organizer, select the screen and click the Export button on General tab. That way, the screen will be exported to an .E2f file.
Then, via E3Studio, create a new screen, right-click it, select the Import option, and retrieve the .E2f file previously generated by Elipse SCADA.
Print Friendly, PDF & Email
Leave a Reply
