Question:
Where can I find the Applet.zip file, to be used with Elipse Web?
Solution:
The file is installed alongside Elipse SCADA, and is in the following folder:
C:\Program Files\Elipse SCADA\Applet
To use Elipse Web, copy the Applet.zip file to the web server’s folder. In the case of IIS, the path is
C:\InetPub\wwwroot
For further details, please refer to Elipse SCADA’s user manual.
