Question:
Which Report’s property sets up the distance between data when printing it?
Solution:
This can be done via CanShrink property. When it is set as TRUE, the distance between data is set up according to the size of the objects inserted in the Detail section; when it is set to FALSE, this distance is related to the Detail section’s size.
