Question:
How can I access a bit from a memory byte from a S7-200 at E3?
Solution:
To do so, set a tag’s N2 parameter as 108, and its N4 parameter as 5. Then, enable UseBitFields property and use whichever bit you want, because it will be available to be linked as an I/O tag’s property.
