KB-32156: Using indexes and primary keys with Insert, Delete, and Update commands.
Question:
What is the effect of using indexes and primary keys in Insert, Delete, and Update commands?
Solution:
When using an index or a primary key in the Insert command, its execution gets slower. However, the Delete and Update commands’ execution become faster when they have a Query clause.
We also recommend that you use indexes to improve the Queries’ performance.
Print Friendly, PDF & Email
Leave a Reply
